spitzer
A room. Three walls are thick concrete/plaster/brick.
The "door" or "fourth wall". How to prevent low, including very low (under 100 Hz), frequency sound from getting through?
Rockwool, fiberglass and similar materials only absorb or block high frequencies, so why would one use them at all as part of the construction? I've read somewhere that the blocking effect of drywall or fiberboard decreases with every consecutive layer, however frequencies are seldom mentioned in that context.
I would assume that 10 layers of fiberboard would block low frequencies more effectively than 2 layers of fiberboard and whatever thickness of rockwool behind it (air gap or not, your choice). Right or wrong?
