bluesfordan
Member
still mulling my music room options. There's a master bedroom on the first floor, it is rectangular but also bigger in all dimensions.
current room is 109" (2.77 m) wide by 133" (3.37 m) long by 88" (2.23 m) high = 738 ft[SUP]3[/SUP] (20.9 m[SUP]3[/SUP])
master bedroom is 137" (3.48 m) wide by 158" (4.01 m) long by 91" (2.31 m) high = 1140 ft[SUP]3[/SUP] (32.3 m[SUP]3[/SUP])
There are three windows, one centered on the north (end) and two side by side centered on the east (side). There are already heavy drapes in place. There is a long closet offset on the south (end) wall and the room entry door is on the west (side) at the corner. There's a ceiling fan roughly dead center of the room. I can actually use that in another room so removing it is no problem. The wall to wall carpet is heavily soiled and everybody agrees it needs to go. The closet doors are poorly hung mirrored bi-folds that never worked right from day one probably due to weight and they'll probably be removed as well no matter what the room is used for.
i could construct bass traps for 3 of the corners, don't know about the corner where the door is.
Would I want the desk at the north end or the south end of the room? My thought is at the south end in front of the closet, with large gobos acting as reflection absorbers behind the monitors. Same for the side reflection. The higher ceiling would make hanging a cloud easier. The drapes would help as diffusers.
