D
D'Lunacy
For as long as I've been playing, I've always had a nasaly sound to my tone in my lead playing, which I hate. It doesn't matter what guitars I'm playing, or what amps I'm playing on, it's always there.
Doesn't matter if I use light or heavier strings, it's there. Doesn't matter if I scoop the mids (which I try not to do for leads), you get the picture. Even now, with computer recording, and using high end VSTs, I get really good sounds, but when I record, and listen to the playback, there it is, that snot nasaly tone.
The problem is clearly my fingers. How in the hell do you change something like this?
You could also give up and take up slide. The world needs another Duane Allman and slide will eliminate your fingers as a variable.
