D
davecg321
How do I set this up for my drum tracks in cubase artist 8....?
Yes, the point of the FX channel is to have parallel compression. You could also do this buy setting up two group channels and setting up the aux to go to the second group channel. (putting the compressor on the second group channel)Just curious (I don't know Cubase)... Can't you insert plugins on a group track?
As you start using parallel compression, be aware of phasing / comb filtering... it happens because the compressor’s output will have a slight delay, owed to the processing time of the compressor.
We’re talking milliseconds or fractions thereof. Cubase 9 pro has a delay offset feature to combat this issue. I don’t know about artist.
I just use one of my outboard comps that has a "Mix" knob, which is basically a built-in parallel compression setup, so I can dial in the amount of uncompressed and compressed flavor I want.
When I do parallel compression I often like to omit some tracks from the parallel compression so that doesn't work for me.
Not to speak for BSG, but I don't like to add the hat mic in the parallel compression. Sometimes I leave out the room and overhead mics too. Why I'm using parallel compression will dictate which mics on the kit will be routed to it.What do you mean by "some tracks"...which tracks?
Usually I would just put the kick and toms into the parallel compression.
I guessed you would say something like that...I just wanted to be sure.
Yeah...I don't run the entire kit...I didn't mean to imply that in my post. It's often just the Kick and Snare...sometimes the Toms too.
I have 3 racked Overstayer comps, that all do the internal parallel compression and have the Blend/Mix knobs...two are VCA-based, but one is a FET, and that's the one that kicks ass for drum use.
I usually just use the CLA-76 for parallel. I also have all the Slate 1176s, the FG-Stress, FG-401, U73b, the Waves dbx-160, CLA-2A & 3A, but the CLA-76 seems to work the best for it. And it's pretty simple to use.
Sorry, didn't mean to list all my compsThey all have their uses though
I can't commit myself to my drums... once I bounce, if I don't save the MIDI (oversight), I can't edit them any longer. Since I like to go back every couple years and redo the tunes with what I've learned, this doesn't work out well. Therefore, I leave the drums in Superior as MIDI, process them within the plugin (they've added cool and effective fx within), then again as a whole on the SD instrument track. That way, I can still process them individually and also as a whole.
So, I'll choose one of their compressors (usually the 1176 clone), throw it on the snare bus (toms, OH, kick etc) in SD, get a few dbs moving, then use another compressor (usually API2500) on the whole Superior track.
