S
straight8413
I have had a ART Pro MPA II for about a year now that I got off of eBay used...I semi-retired the unit for a month or two while playing with a different preamp, then when I eventually fired it up again the 2nd channel doesn't function. If the gain and output level on that channel are cranked I get a tiny bit of signal but nothing more than that. I've swapped in and out known working tubes and swapped the tube from channel one, with no change in performance. Channel one works as it always has.
I have a ART Pro Channel with this same issue as well, with the Gain, Preamp and Master controls cranked it will pass a very VERY faint signal but nothing more.
Anybody have this same problem with these units, and was it ever resolved?
