D
dkpz64
Can you transfer files to a flash drive with the dp32 instead of hooking it up to a computer? Don't have computer in studio. Please Help...
no, the files have to be transferred to the audio depot folder first, then connect to the PC and you can copy them from there.![]()
what if you take the sd card to a computer, can you transfer them that way?
I want to transfer the master file to burn it. our dp32 does not have the cd burner
thanks, just wish you could zip it to a flash it would be faster
I just did this with a DP-03SD. The files will transfer from the SD card to the computer, just make sure to go through the Export process, this converts them from the SD's .FAT partition to the .WAV partition. The DP-03SD requires a separate export procedure be performed for each song. Once all songs are converted for export you can grab the SD card and go to your nearest computer.
Using Windows 10 on my desktop, I converted mine to mp3 on CD for use in my car. I keep the original .WAV files and the mp3's stored on my PC.
I don't have a DAW yet.
