E
ecc83
You're absolutely right. I was contemplating a USB A/I, thanks to the advice of the posters above... but only had a brief glance at a couple, and didn't realise they came with built in Midi ports. How thick am I!
I'll now look at them a bit more closely. This does seem like the way to go and, as you point out, it'll save me having to buy a new midi-USB cable.
The Steinberg you linked looks pretty good, especially as it comes with a version of Cubase, which I've used in the past. I know it's a cut down version, but it'll probably be more than adequate for my needs for a while!
Thanks!
I get a bit of stick here for my hobby-horse railing against cheapskate AI mnftctrs who don't fit MIDI ports to some of their budget (and NOT so budget!) AIs.
Peoples often respond that "everything is USB these days" It ain't. Then the MIDI-USB cable is trotted out as a final catchall but I remember some 5 years ago that peeps were having driver problems with those!
If anyone is at all serious about MIDI get a fekkin' interface with DIN ports and there is no better software than Cubase for MIDI (started life as a sequencer after all!) even if you use Reaper for everything else.
