rayc
retroreprobate
"DARK" Tone update.
I decided to do some experimentatal recording to test things today.
Before setting up mics etc I sat & thought for a bit...
I had a brain wave -
1. Record DI with an amp clone pedal (AC Tone - VERY bright).
2. Record DI with a Maximiser stomp box (I had one I'd bought 2nd hand & VERY cheap & not used,
3. Record DI with normal levels
4. Record DI with the Preamps at MAX.
Results:
1. Signal still disappears just beyond 5Khz even when I had the hi knob at FULL.
2. Despite the added top end from the enhancer the signal still disappears just beyond 5Khz
3. Still 5Khz
4. With the preamps cranked ALL the way the signal captured went a little beyond 10Khz but it was a fairly steep taper from before 5Khz but it was impossible to play anything decent at that level as it was almost perm IN THE RED.
NO speakers/cabs/mics in the chain.
Thoughts?
Results:
3. Still 5Khz
Thoughts?
