andrushkiwt
I've only used MIDI for 2 things - Superior Drummer and vst/stock synths. When using my DAW's MIDI grid for Superior Drummer, changing the velocity of a note does what it should, it raises or lowers it's volume and intensity. However, when I use this same MIDI grid for synths, the notes are always at the same volume, no matter which direction I click the velocity meter. 100 sounds exactly the same as 40. This makes programming synth sounds difficult. It is the DAW's MIDI map for both SD and synths, not via some other means. Any ideas?
