V
Vibesx
Hello.
I have a pair of KRK Rokit RP8's G3 monitors, connected through RCA cables to a Numark Mixtrack Pro 3 dj controller, connected to my PC via USB and there is a humming noise coming out of them. From what I've read, it might be a ground loop problem, but I've already tried some things and am running out of ideas:
- changed power cables around to be in different power outlets
- bought a ground loop isolator to no avail(although a pretty cheap one... maybe a better one would have a better outcome?)
- connected the monitors directly to my laptop through a 6.35' -> 3.5' cable; no humming noise
- connected the dj controller to my laptop, both while unplugged and plugged to a power outlet and the humming noise was there
- connected one of the monitors to the DJ controller through an TRS cable, converted to 3.5' through an adapter, connected to a 3.5'(mother) to 2 RCA's(father) splitter; humming was gone, but audio quality obviously changed
What would be next would be DI boxes, DAC's, audio interfaces... but these are kind of expensive solutions that aren't sure to fix my problem, so trying to grab some more ideas. Somebody even suggested some custom balanced RCA cables, although I don't even know how that's possible or how to do it. The problem is that I only have RCA outputs from my dj controller, so using balanced cables would be kind of a problem.
Waiting on your suggestions.
Thank you.
Thank you.
