famous beagle
Ok, so I'm using Garritan JBB3 with Reaper, and I've recorded a nice little tenor sax line. I'd like to go in and draw some varying vibrato now. The JBB3 manual says this is done with MIDI Controller CC#17. So I open the MIDI editor in Reaper and pull up the menu list of controllers. This is where it gets fuzzy. There are a whole bunch of things in the list, starting with:
Velocity
Pitch
Program
Channel Pressure
Bank/Program Select
Text Events
Sysex
And then it starts in with numbered items:
00 Bank Select MSB
01 Mod Wheel MSB
02 Breath MSB
etc. The numbers continue on up to 119 with varied descriptions and many left blank, and then they start over again at 00 and climb back up to 31 with other various things.
Nowhere in the list did I see "vibrato" or CC#17. I tried using the number 17 parameter (both of them), which was labeled "GP Slider 2," but that resulted in no change.
So ... my question is how do I find out which parameter in this list coincides with CC#17?
Thanks to anyone who can help. And if you can shed some light in general on this parameter list, I'd be appreciative!
Velocity
Pitch
Program
Channel Pressure
Bank/Program Select
Text Events
Sysex
00 Bank Select MSB
01 Mod Wheel MSB
02 Breath MSB
