Hello,
I'm working and searching on this for a long time now but I still haven't got the point to get full use out of my hardware. It's about the Behringer BCF and BCR2000.
I'm using FL Studio and it's quite easy to link a control in the program to the hardware. (select the parameter, link to controller and move the hardware control )However midi output is another story. I can set the output port in any plugin to 102 (the communication port of the BCF2000) but nothing happens when moving a control inside the plugin (not output is send?).
In the FL Studio dashboard plugin I can manually create a slider for example, and set the cc number and channel and that works fine (the hardware receives the value from FL Studio). But it doesn't get me anywhere since there no VST plugin involved in this setup. Anyway this states that I know at least a bit about midi and my hardware is setup&configured well. It's more software related I guess.
From this point I have several solutions that would help me out;
-A VST plugin wrapper/host that supports midi in and out, and sends direct midi out (cc messages) when a parameter changes. This wrapper should be loaded inside FL Studio so as a VST for example
-A way to edit the Mackie Emulation mode of the BCF2000, or send feedback on the 'free controls'. (a group of unassigned controls in the Emulation Mode) In my midi monitor they are registered as pitchbend messages on a specific note ,but I can't manage to send pitchbend range on these notes back to my controller
-Software to edit/modify a plugin so parameter changes trigger midi out cc messages
-A solution from someone here?
I already tried so much, even got the demo of Midevice.com], comes very close but again no output from the virtual device on parameter changes.
All help is appreciated, I'm really getting stuck on this and the controllers are waiting for too long to get started..
Thanks in advance,
Jeroen
Thanks in advance,
Jeroen
