Resurrect
Please cut this to pieces. But only if it needs it. I am so tired of trying to critique myself.
Interesting.
mix: thought the acoustic sounded pretty good, especially with the synth in the beginning, but I'd double it and pan another right, eq'd slightly differently. Hearing it in the one ear gets a bit tedious after awhile. I'm not a drum guy, I use software for mine...and honestly can't tell if that's a real kit. The snare sounds very dead. Needs some body maybe?
song: the meter of the vocals caught me off guard...they are very fast paced for the strumming pattern and tempo - really cramming a lot of words in there!
 It's been a while for me since I've last played the drums, and I did make it too busy. Thanks for the thoughts.That's two guys who have mentioned the "bass" I'm not sure what u are hearing. There is no bass in this song, other than the bass drum. =D
Are using an impulse file on Reaverb? It sounded like Silo or one of those big ones (the part around 2:15), not sure what effect you wanted at that point in the song, but it struck me as strange.
For a song that is dominated by acoustic guitar (and some early synth), maybe rethink what you want from drums (if anything) in the song?
 Not sure if it was what I wanted. I wanted something that emphasized the hoplessness of the lyrics there. I wanted the vox to sound alone. somehow set apart. I suppose I didn't succeed the way I wanted. And yes, I will redo the drums. I hadn't played drums for several months before recording this and was pretty rusty. I need something simpler. Just a quick note. I'm fairly sure you don't need a new snare, unless it's cracked or inflicted with some other obvious damage. If it's not damaged, then you just need to get some new heads on it and tune it properly. Everything that has been said I agree with. Drums sound dull. Acoustic sounds pretty good, and the vocal performance needs some work. Also - I kept noticing a drone of some sort in the right speaker. I think it was an electric guitar, but it just kind of sounded out of place. You could also work on the vocal pitch, too.
Keep at it, though, we all have to start somewhere! Thanks for sharing!
That would explain why I couldn't hear it.
