famous beagle
Hi y'all,
I just recently got this interface because I wanted to have more outputs for using external gear. I've got in installed (Windows 7), and it's working like a champ. The only thing is that the input levels seem really hot compared to my Steinberg UR22.
For example, I usually run into my Presonus MP20 as a direct box when recording guitar with amp sims. The UR22 just has two combo jacks for inputs. I would have the input trim knobs all the way down because I was using the MP20. I was able to set the input knob on the MP20 between 9:00 and 12:00 usually and get a good level (around -15db or so) going into Reaper.
When I hooked up the 410, I first ran into the line inputs on the back (it has 2 1/4" line inputs for CH 1 and 2 in the back and two combo jacks for CH 1 and 2 in the front. You can only use one at a time). With my MP20 set the way it was for the UR22, I was easily clipping when not even really digging in.
So I plugged into the front combo jacks, for which the input level knobs and pad button switches work. I had the input knob all the way down, and I was still easily clipping. I engaged the pad, and I could still clip it fairly easily by just digging in a good bit.
I had to basically back the input knob on the MP20 all the way off in order to get the same decent (-15dB or so) level into Reaper.
So, I'm just wondering ... where is all this extra gain coming from? I have the input knob all the way off on the 410 with the pad engaged, and I've rolled the input all the way off on the MP20. What gives?
Anyone have a clue?
Thanks
Anyone have a clue?
Thanks
