G
GendoPose
Hi All!
There's this very strange thing happening at the start of this song after the first snare hit..
Basically, it's almost like the mastering chain stops the bass from coming in straight away, I can't figure it out.
Here is a dropbox link to the song I'm working on - it only happens in the first few seconds, the rest of the song is fine.
Any ideas?
Here is the current chain;
SSLComp - 1 or 2db of compression
Ozone 5 EQ - 0.5db boost at 160Hz and 1db boost at 12kHz
Ozone 5 Comp - Expanding between 20 and 200Hz, light compression between 200 and 10kHz, expanding 10kHz and up
L2 Maximiser - Slightly compressing to bring up the volume
Ozone 5 Imager - Mono 200Hz below, narrow between 200Hz and 2kHz, wider between 2kHz and 10kHz, even wider 10kHz and up
Ozone 5 Maximiser - Bringing the RMS level up without compressing too much
Any ideas?
