miroslav
Cosmic Cowboy
I've tried from thin to very thick...and I've settled on the yellow/.73mm picks as the perfect pick for me, especially the Tortex III that I mentioned above, with it's more bowed sides and sharper point.
I don't use the picks in the "flat" position, which is why I don't need anything thicker/stiffer. I tend to play with the pick half-way on-edge, and only a very small amount of the tip showing and hitting the strings, and with the pick on edge like that I am simultaneously also able to pluck the string with the my finger. So basically...I'm often hitting the strings with with pick & fingertip, which has a specific sound, compared to just one or the other.
When I need to get some faster licks in...I can easily turn the pick more toward a flatter position and just work with the tip of the pick and no fingertip.
Playing that way has also made it very easy for me to play with just my fingertip, and no pick...which I do often, while holding the pick in-between my teeth.
Playing guitar that way also helped me with finger picking the bass as opposed to using a felt pick, which I used in the beginning when I first tried playing a bass. Now I'm strictly fingers...unles I want some real prominent attack, then I'll use a felt or rubber pick.
