Farview
You have to be more specific. 0db doesn't mean anything. 0dbVU is where you should be on the meter on the mixer. 0dbFS is where you should be nowhere near on the zoom.My overall concern now is that using some of the tips above I'm not approaching 0db on the meters like I think I should but I'll keep at it.
Analog and digital equipment use two different types of meters, which use two different db scales. On the analog side, 0dbVU is line level, which is right where your signal level is supposed to sit. On the digital side, 0dbFS is the absolute ceiling, where clipping occurs, and you shouldn't really be with 8-10 db of it.
This might be part of your confusion. If you are looking at the meters on the board and the meters on the recording device, they shouldn't be reading the same thing at all. A steady 0dbVU signal will probably read around -18dbFS on a digital peak meter.
