M
mesaboogie5050
Okay, here is what I have going on.
I have used a multi band compressor to compress the lows, low mid range, mid range, and highs.
Now, I am a noob at this stuff. I want the final compression to run through my analog compressor. The reason why, is I've noticed the warm sound I get from it, I'm not getting with any of the free plug ins that come with Logic Pro X.
It can be used as a limiter, as it goes up extremely high on the ratio.
How do I know how high to put it? Because when doing it with plug ins I have always used an adaptive limiter. It does not have a ratio. The ad limiter plugin Just shows the input, the gain, and ceiling DB.
I know you can not tell me what ratio to put it at without hearing the song first. But I guess what I am asking, is what am I looking for? since I'm not really compressing in the traditional sense, like with each instrument when mixing, or even the multi band compression. Since, I am compressing the entire song, what am I looking for? How much compression is typical?
I need it to be enough that I can turn the make up gain up loud enough to use it like the Ad limiter and go somewhere around -2db. To bring the whole song up to volume.
So, I understand how to use a compressor as a limiter... On a track. Say, drums. But I do not understand how to do it on an entire song, because I don't want to squash all the dynamics completely.
If I turn the thing up past 5:1 into the limiting spectrum will I not squash the song by doing so? And is that why an adaptive limiter does it without a ratio? Or does it have a ratio I don't know about?
