S
Stubby03
I got a good mix going, but my F and A note on the bass are a little loud, can I use a parametric eq and get those two notes a little more in check.
What else have you done to the track re. processing?
My start point would be to automate the volume on individual notes, but that depends upon the style being played. A little carefully applied compression can be useful. I wouldn't reach for the EQ for this problem.
Yes.. but it also can come of simply uneven picking' playing.
What if he's recording direct and listening through headphones?
Room don't matter then.
... I would automate them before compression.
That's.. interesting. But I'm sitting here thinking, a typical bass track that could easily be dozens of edits?Yeah...either automate or just manually run through the track, slice as needed, and drop the levels down of the offending notes.
I wouldn't reach for compression or EQ to solve a level problem whenj working in a DAW where precise editing is so easy.
