You'd be better off separating them and using them to treat different corners of your recording space.
To answer your question as you asked it, the bass trap will be unaffected in its performance. If you build your bass trap properly, the insulation sits on top of the frame, not inside it. The dimensions of your frame are the same size as your insulation sheets.
