N
notCardio
I walk the line
Anyone know where I can get an input jack like this? Being plastic, mine broke.
...Or build your own TubeScreamer clone!
Behringer have such massive buying clout that they can have stuff made exclusively for them and, AFAIK, will not supply spares to Joe Public*. I tried to get parts for my BCA2000 from them and despite proof that I was a bona fide service tech of 45years standing, they would not play ball.
If you are lucky it might be a 3rd party part "Preh" are good place to start.
Note (grannie's and eggs not withstanding) the best way to get that jack off the PCB is to "destroy" it in situ and then carefully unsolder and pluck out the "bits". Suckers and other means are likely to bugger the print tracks.
* A practice I would outlaw in this country were I able. I would tell firms, "If you want to sell here you HAVE to make spares and service reasonably available."
Ooo! JS-64547 Slimline Jack Socket 6.4mm for PCB Mounting
Anything like?
"I don't even know if I like it. It broke before I really got to try it out"
Just "tack" a jack lead to the broken connector to give it a go.
I would just buy the TS9 and be done with it.
throw it in the bin and get a boss SD-1, it's probably the best sounding cheap overdrive pedal
OK, let's see...I've got a DS-1 (I'm guessing that's what you meant)
This is good point. The Input jack will need to be stereo. Did he say which of the jacks is broken?If you do hunt down a 1/4" jack, it would be handy to know if it's the one that needs the internal switch or contacts that powers the unit up when you plug in.
Both exist. I'd guess he meant SD-1.
