S
Yeah copy and paste the mediafire links from the first post. I thought since they weren't active links they wouldn't work but copy and paste does the trick.
and offtime bass?¿?!¡! heresy i tell ye! https://www.facebook.com/ParisInPaintI thought your mix was a little bit too harsh... I corrected this problem by turning the song into something a little bit muddy (not done on purpose) yay \o/
EDIT: Mix corrected
Well, I corrected the mix once again and I'm pretty happy with the result, I decided to change some EQ and compression on differents parts of the mix with a little bit more agressive snare and a punchy kick.
By the way Stragedays, I like your kick very much, does it bother you to share your preset?
Your snare is a little bit ear piercing.
your whole mix miss something, I don't really know why but it's doesn't sound "full" (frequencies missing?)
and the background voices are lost in the mix (and the background voices harmonies are lost too)
that's all I have to say.
sorry, maybe "preset" was not appropriate, maybe "setup"? is more appropriate?
(english is not my first language)
mind to detail a little bit more your modifications?
Be careful its easy to go one route and get stuck. I know what you are trying to do though, but you have to be careful and not loose clarity.
This is my latests, I used more NS10s to get the upper mids to sit, but also using my bigger monitors to keep an eye on the lower mids, low end. (mids being the click of the kick and the tops of vox/bass)
Theres lots of ways to mix this, so this is another version really. The kick is more Ben Grosse style.
Hi, heres the mix i done of the song!
EDIT : Did a better version if anybody is still reading this thread?
