It’s a big time waster running about looking at MSDS sheets and trying to play chemical engineer, because you really don’t know what you’re looking at or what it means in practical terms.
Really.....?
You mean no one will know how to read the basic chemical contents listed on an MSDS sheet and any warnings that are included....?
C'mon now Beck.
All this stuff about "back in the day" doesn't change the fact that there are some denatured alcohol mixes that have some nasty additives and poisons, and not every denatured mix is identical from brand to brand.
I'm not worried that anyone will drink the stuff and get poisoned...but
some of those additives (liked acetone) can melt certain plastics.
That's not being irrational and uninformed....rather just the opposite.
I've seen acetone do that....and I don't see the point of risking that when isopropyl is probably more readily available and safer.... but I guess you feel that's unnecessary "silliness".
You also mentioned xylene....sure, it's great for removing all kinds of gunk and glues....but it's also even worse than acetone on some surfaces, and not to mention, harmful when inhaled.
I guess knowing that information is also "silliness"....?
There are many decks that have a plastic covered/coated erase head, and other plastic parts in and around the transport. I've spoken to TASCAM and FOSTEX in the past about what to use for cleaning, since I too have an assortment of cleaning agents, not just isopropyl alcohol, and I am aware that some of those chemicals are not safe on some surfaces....and they both said to be careful when using certain cleaners, and that isopropyl alcohol would be the safest/best choice for daily, basic cleaning.
That's really the point here that you seem to be intentionally ignoring and going against for some strange
reason...?
You know, I don't much care what anyone uses....it's not going to matter much to me if they use isopropyl or denatured alcohol, or some other chemicals.....but it will matter to them if some of those solvents end up melting some plastics on their decks, maybe not in one application (though some plastics can melt fast) but over time, some solvents can slowly dissolve them.
I use isopropyl alcohol for regular cleaning, and I've not ever had a need for something stronger....even with SSS tape gunk it does the job.
For restoring ancient decks with 30 years of dried up gunk.....that's a different story, and that's not what we are talking about here.
