mjbphotos
Moderator
The difficulty I am having is I only have the capacity to record 2 mics at once and like to track vocals and guitar at the same time. I also usually have my vocals central or slightly left so that and the guitar fight for space.
I've been using my LDC pointed on it's side, towards the neck/soundhole meet, but I'm convinced my mixes are missing something and I don't know what it is. Could I pick your brains? https://homerecording.com/bbs/gener...ciante-masters-also-enclosed-download-365228/ - I believe it could be a reverb issue - I don't think it's the actual recording of the guitar.
Should added "using one mic where there is only acoustic guitar and vocals" however I'd still believe it'd be the same answer.
I've got a few mics myself - much like OP - however I've found only the LDC are capturing this situation best. Also have x2 SDC (not matched)
Consider changing your MO and record the guitar first, vocals separately. Not only gives you the opportunity to use 2 mics on the guitar but do give separate space for the guitar and vocals - no bleed.
