B
Battie
Undoubtedly, there are many advantages to using small, low watt tube amps for studio recording, but I'm interested to know if the recording process is any different when using a small amp, such as the 1 watt Blackstar HT-1 10" combo, to using a higher watt amp with a 12" speaker. From one sample recording I've heard of the HT-1 via an SM57, it seems the 10" combo has a good but narrower, thinner sound compared to the same amp through the 12" extension cab, which had more depth, and a fuller sound. Not a surprise, but is that actually a problem? When I mix guitars I usually roll off a lot of the lower frequencies anyway. Is there a reason why a 12" would be preferable to a 10"? Will a mic that is generally used for recording lower frequencies (MD421, RE20, D112 etc.) bring out more in a 10" and provide more depth and a fuller sound? Will placing the mic further away from the grill cloth also deliver more depth?
Just some initial research to help with purchasing decisions. I'll naturally experiment with whatever I end up buying.
Thanks in advance...
Wow dude, quite a compliement coming from you, so thaaaaanks a bunch dude!!!! Don't think playing live is gonna be in my future really, you never know, but I'd doubt it very seriously....Thanks again Greg...
