W
whatapoof
I’m getting a bad crackling noise when recording in Ableton Live 8 that I can’t seem to pin down. I initially thought it was my equipment: bass guitar, guitar, pedals, cords, etc. but tests of all that stuff on an amp turned up nothing but typical guitar hum (which would be nice to reduce) but no crackling. The crackling when recording does seem to be connected to the hum though. The stronger the hum the more prominent the crackling is.
Then I thought it might be the interface (M-audio fast track, kinda old). I tried a new interface (Focusrite Saffire something or other) and got the same crackling noise, so I ruled that out. Although, before I tried that I did change the USB cable connecting the interface and it seemed to help a bit…
Then I thought it might be the program, Ableton. I tried messing with the bit depth (set at 32), not really any change there, the in/out sample rate 44100 or 48000, no difference. The buffer size is set to 32 samples when recording. I tried raising it , lowering it etc. no difference as far as the crackling. The noise that occurs when setting the buffer size extremely high was a different noise all together. The crackling, to me, does not sound like a digital noise.
I also tried recording in Garage Band just to see if the problem followed me over to different software and it did. So, its not just an Ableton problem.
Could it be the internal sound card? I have a year old iMac:
Processor 2.5 GHz Intel Core i5
Memory 4 GB 1333 MHz DDR3
Software Mac OS X Lion 10.7.4 (11E53)
Or is my best bet to focus on reducing the hum with outboard gear like pre-amps and what not? I use a Bass DI box to ground the signal (but I don’t think this reduces the noise much) and I plug all devices into a “Furman ss6b pro plugs” power conditioner, a low-end conditioner but it has helped with past noise problems.
Any ideas/suggestions would be much appreciated. Thank you.
