famous beagle
You might have a bad solder joint on one of the pins mounting the trim pot to the channel strip. It would crackle from being dirty like the rest but will also cut in and out intermittently with a cold solder joint. It could also be worn out copper or carbon inside, or the copper contacts may not be making good enough contact with the carbon.
You take the channel cards out from the bottom:
Make sure the unit is off and unplugged.
1. Remove the bottom panel
2. Remove the metal support that runs across the channel cards (Two screws on each side)
3. Carefully pull off the Input Buss PCB from the eight channel cards in the section you’re working on (rock it slightly back and forth while pulling up). They are linked together by ribbon cable. In your case for CH 2 you remove the first one.
4. Unplug the 3-wire plug from the XLR PCB near the inside rear of the unit
5. There is a screw on the outside rear of the unit for each channel card. They are right next to the Line Input of each channel. Remove the one associated to the channel card you want to remove.
6. Desolder the three wires from the channel fader for that channel. Alternately you can also remove the two screws on the top panel holding the fader, but I find having the fader dangling while working on a channel card can cause the wires to snap from excessive bending back and forth.
7. Remove all the knobs, including the grey fader knob for that channel. Leave the buttons as is, as they don’t come out that way.
8. Remove the nuts from each knob preferably with a socket wrench. The channel will then drop out. It’s a good idea to put the mixer on its side so you can support the channel card with your other hand while removing the last couple nuts.
Reinstall the channel card following the above list in reverse order. If you can’t remember how a wire goes or something you have 15 other channels for reference.
By the way, I use deoxit on the pots from the inside rather than trying to spray it from the top panel. Not sure how you are doing it.
Hope that helps. Feel free to ask for clarification on anything.
Ohhhhh ... from the bottom! Ok I'll try that, thanks!
