Should I change resolution/bit depth?
  • Thread starter Thread starter bluedaffy
bluedaffy
bluedaffy
If I recorded a song at say 44.1k would it be beneficial to edit the song and tracks at 48 or 88.1k? same question for bit depth.
Or would the process of converting the tracks degrade the sound more than editing at a higher resolution would benefit?
Thanks
Tricky one... And a lot of "that said..." to follow.
What you have is what you have. 44.1kHz files aren't going to improve by being set to 88.2kHz. That said, some EQ's might push aliasing noise higher at higher rates. But that would work the same on export (rendering to 88.2kHz is going to put those plugs in a 88.2kHz mode). THAT said, many of such plugs already calculate at the first multiple just because of that. *THAT* said, can you hear a difference if you export in both sample rates? And if so, do you actually prefer the higher rate?
On to resolution / word length -- Same sort of thing. Ideally, you should've been in 24-bit from the start (avoids additional dithering noise, improved footroom for low-level signals, etc.). If you're in 16-bit at the moment, your DAW is likely calculating in (at least) 32 bit anyway - So again, modifying individual files isn't really going to help anything.
Side note on that one (which I couldn't get another engineer to understand a few days ago) -- If all your source files are 16-bit, you should *STILL* render in 24-bit. Those calculations are being done in a floating-point architecture and the benefits of the higher resolution are still going to be intact. You can't do anything about whatever dithering noise was on the source tracks, but you don't have to add more as long as you're in 24-bit.
Wow, that's an awesome response, thank you for that! So all of my songs were originally recorded in either 24 or 32 bit (depending on what session they came from).
So I need not worry about the last little bit you posted about? The part about it being a good idea to render in 24 bit if the source was 16...
By the way, how do I do the quotation thing that I see so often in posts? the thing where I can take a selected piece of what you said and put it in my post.
You can "Reply With Quote" --- Or simply use the "quote" tag (quote) and (/quote) using brackets instead of parentheses.
Abraham Lincoln said:
Don't believe everything you read on the internet just because it's between quote brackets...
