T
Telesonic95
Could a pair of headphones such as the Grado GS1000i + Grado RA1 amp be a good substitute for a pair of monitors like the Adam R7X?
I hope that's a well known reference.Mixing with headphones is like trying to build a model of an MS Escher painting.
But is it true that you have to have speaker monitors quite loud to hear the bass?
Had a Russian girlfriend for a while. Talk about translation problems!
Never a truer word said.It depends.
Ok, a truer word was said !Great sound is very subjective
It depends. If you want to record a band or acoustic musician and want to hear every little sound and noise, then monitors are your answer.
I agree. My monitors aren't in the range of John's but I can hear little things on phones that I can't always on monitors. In a way, that's logical, given that the sound is closer to where your hearing really is.Not sure I agree with this - I can hear a lot more subtle detail with headphones.
If I want to hear deep into a mix and listen for some subtle detail that is not clear on monitors, then I use my closed Sennheiser HD 25-1 headphones to bring it out.
And my monitors are top quality Geithain RL906 costing in the region of £2.5k the pair, so I'm not using poor monitors.
Yes, you *do* need good monitors to do the job properly, but headphones are also an essential tool as they enable you to shut out everything in the listening environment and concentrate deep into the recording.
You really need both.
