Fostex Model 20 Alignment: Practical vs. Ethical
A Reel Person
A Reel Person
It's Too Funky in Here!!!
I'm going thru alignments on a Fostex Model 20 mastering deck.
The manual states that 0VU is referenced to 514nWb/m! This would strike me that it's factory set and intended to use +9/185 high output tape, (499, 996, etc.), and the 0VU is set on the hairy edge of MOL! Being that's what the manual states, it strikes me as funny anyway. However, using this deck at 15 IPS on +9 tape must sound very clean, punchy and impressive! (Just don't hit it too hard above 0VU!)
The practical thing is the bulk of my tape is +6/185 tape, 456/equiv (031 media), or standard 457, 3M 226, some 806, other various standard or lower output tapes (can't remember them all), and yes, some Quantegy 480 and 3M 996 high output tape in smaller amounts. I am ready to recalibrate and I can't decide what standard to use. The (lower) practical one for my own purposes, or the (higher) one that's stated in the manual?
The ethical twist is that after calibrating I'll likely be selling this unit to locals via Craigslist. Just to set it for factory and tell the next owner to get some +9 tape, or set it to +6 (@MOL) and recommend using 457 all the way across? The Model 80 8-track is set for G320, which would be like running 456/457 with 0VU at the hairy edge of MOL. Again, that seems odd, but it's FOSTEX, and they were definitely marching to the beat of their own drummer.
If there's a small chance it won't sell at all, I will be keeping it, nonetheless.
I can't decide. I know what seems expedient to me, (lower levels using +6 tape), but to just set it to factory specs to hand it off to the next user and tell them to use +9 tape or let them make adjustments as they see fit?... (seems "right" vs "expedient" or "comfortable")
Mastering to a +9 tape doesn't sound like a bad idea, but my stocks of +9 on 7" or 5" reels are minimal, and my estimate is that +9 tape is more expensive than +6 tape to buy at the dealer level.
The Fostex Model 20 was designed for and factory set for +9 tape, so anything less would not be using the hardware to it's greatest advantage... is the most common sense idea I can draw about the situation.
If I could decide, I could move onto the calibration and be done with it!
Any input or recommendation, tapeheads? For some reason, this question has me way outside my comfort zone! I typically don't use +9 tape. I'm not used to it, but tape is tape, and I can read the manual! Aaagghh!! I think I'm having "analysis paralysis"!
Thanks!
:spank::eek:;)
Dave, I know it is funny to see those levels, but they're based on European (IEC) standards rather than NAB, and are meant to be used with the recommended 457 class tape. +9 tapes weren't available yet when the Model 20 was introduced.
G320 (German 320) is closer to 280 nWb/m NAB. It's a different scale altogether.
Edit: Actually I worded that wrong. G320 is equivalent to 280 nWb/m NAB or IEC because of the different way we measure compared to German. Jay McKnight has a good explanation somewhere here on my overly crowded hard drive. I'll try to find the link.
Yes, and...
Thank you. I also determined from what I read, reference info, etc., that G320 was somewhat lower than 320. The Model 80 refers to 320nWb/m, and with all things considered I determined it to be calling for G320. G320 was referenced in lots of the white papers I've read. I set my Model 80 to G320 using -4VU and a 185nWb/m cal tape, but what of 514nWb/m?
The Model 20 manual refers to the Fostex 9102A cal tape, or STL 53-1. Referencing an MRL 21J205 (15 IPS @ 250nWb/m) and would read -5.5dB below 0VU. The equivalency charts I'm reading would be somewhere just below 500nWb/m.
Choosing and Using MRL Calibration Tapes for Audio Tape Recorder Standardization
*I see G320 referenced, but nothing about 514, except in other tables a G510 reference is 450nWb/m and +8 over 0VU@185. I've read the dc-vs.-ac measuring method to arrive at these standards is appx. 10% difference. However, as my opening thought indicated, 450's just a hair below MOL for a +9 tape.
Tape Flux Measurement Revisited*
"the old German measurement is 10%less than the stated value--tapes identified as 320 nWb/m are actually 288 nWb/m". (the rest of this paper is very technical!)
That info still indicates that the Fostex Model 20 was set up for high output tape. It's modern enough. It's the A2/A8 that probably predates +9 tape.
I think I'm being too obsessive about this. I think it breaks one way or another on whether I want to do my own thing in my own way, or just follow the manual, use +9 tape and live with it. I think if I'm passing it on to a new user and I'm going thru the trouble to calibrate it, setting it to factory seems most proper. Once I found the reference equivalencies, it makes more sense, but yet to make that final decision.
Thank you !
Yep, you pretty much found all the info I remember McKnight covering in one of his papers. The M20 is a strange beast for reference level IMO. The A2 (1982) and the E2 (1986) were both referenced to 250 nWb/m NAB, but the one in between, the Model 20 (1985) has this funky 514 nWb/m flux reference. I'm no expert on the Fostex machines, but I do have the original brochure, which also lists that 514 nWb/m reference @ 0VU and recommends Ampex 457 or 3M 227 tape. Of course 3M 227 all went sticky so today's options would be Quantegy 457 or RMGI LPR35.
The Model 20 came out about 1985. The first +9 tape was 3M 996, introduced in 1990.
I see other decks come up with the 514 nWb/m, like the Tascam BR-20 if shipped to Europe, but the heads are slightly different too... DIN vs NAB. And they all recommend 456 (+6) tape or equivilent. It's been a while since I looked into all this so I can't speak about it off the top of my head as much as I would like.
But the bottom line is the Model 20 Brochure and manual say 514 nWb/m and they both recommend Ampex 457 tape... so that's what I know, whatever that's worth. Sorry I can't be of more help.
Omg!
Thanks for pointing that out. I'd just glossed over it way before. The manual recommends 457 or 227, then in the specs says it's ref. 0VU=514nWb/m. There has to be a contradiction there! I don't feel so bad now about splitting the difference, or just shooting for a ... wait.... I'm still confused.
The service part of the manual states that using a 250nWb/m cal tape shoot for -5.5db/VU.
That, with the recommendation of 457 tape,... means they're running the 457 really, really HOT! However, it would be ideally located to run 996 in it's optimal range.
MAYBE,... the Model 20 may have been updated in the 90s, technical specs, etc., updated in the 90s, but they just forgot to update the paragraph referring to 457 or 227 tape? That seems to make more sense.
ANOTHER difference between what the manual states and reality, is you should be able to get to all the cal points by removing a bottom cover plate. However, there was an additional RFI shield over the REPRO set of adjustments, requiring me to remove the entire top/back bonnet and the RFI shield. That was not referenced in the manual at all. ** MAYBE they added the RFI sheld around the REPRO section when they bumped up the operating level to 514nWb/m?** The pieces of the puzzle are falling into place now.
I'll be honest, IMO*, Fostex really had some innovative devices and ideas, but somehow really didn't have their shit together in the implementation phase.
That says nothing about the Model 20, itself, which from all indications is a phenomenal device! IT's the references and manual that somehow leaves me scratching my head!
I am inching closer to just doing a straight "follow-the-book" calibration and in the turnaround using +9 tape. That really seems easiest, but it's made me put my thinking cap on to work through all these conflicting ideas!
:spank::eek:;)
Myself I would be inclined to set the left and right tracks to standard 320 nWb/m NAB (not G320) and the center time code track to 250 nWb/m. I would do this for North American compatibility and use 457 or equivalent. It may not matter as much to home users with a closed shop, but to those who may be sending out mixes on tape for mastering or just using them on other machines I still think standardization is a good practice. In North America both 250 and 320 nWb/m are common. I have my Tascam 32 set at 320 nWb/m Nab for that little extra so I don't need noise reduction. Something to consider anyway. :)
But have fun experimenting and let us know how it all turns out. Cheers!
P.S. Yeah it could have been updated at some point, but my Model 20 manual has a print date of 1985. I agree it is a bit confusing.
Yes,...
Some other very good things to point out!
:spank::eek:;)
My PDF manual copy has the same print date. It's a download from the Fostex site.
:wtf:
There are 2 points that specifically refer to running the M20 at appx. +9/185, and the cal instructions support that. Recommending 457 is dubious under those conditions. You'd be well in the audible distortion range. 499 or 996 would be just humming along, not breaking a sweat.
:guitar:
Now Im really confused. I had my model 20 aligned once in about 97 or 98 and the tech suggested 456, 457. Now im wondering should I experiment with some RMGI 900?
And so it goes for my...
dilemma.
I'm not finished with this process. It's sat idle for a few days. In my mind it crystallizes that you set ref fluxivity by the book, then bias, etc., and run a +9 tape. Despite inconsistencies and perhaps some conflicts in the documentation, that seems to make most sense.
:spank::eek:;)
Whoa! Hang on guys! You're still not quite getting the difference between peak flux level as measured by German standards and average flux level as measured in North America. It's a different animal. The Model 20 calibration and tape recommendation (Ampex 457 1-mil) is not inconsistent with other decks from other manufacturers calibrated for Europe, including Studer-Revox, Otari and Tascam. The 514 nWb/m peak flux level with a recommendation of 456/457 class tape is not unusual. And remember there was no +9 tape when that deck came out and that version of the manual was printed.
I'd spend more time in the research phase, focusing on the difference between European and North American calibration methods and standards. Also keep in mind that even with North American standards you won't see a 3% distortion level until above 1000 nWb/m @ 15 ips with Ampex 456 or equivalent tape.
Edit: One more thing... there's also no 1-mil +9 tape, except for a special run or two of certain sizes. 1/2" that I know of by EMTEC that used SM900 oxide on 1-mil tape. And 1-mil tape is consistent with all the other smaller Fostex machines, before, concurrent and after the Model 20. Ampex 457 was recommended for the A2, A8, Model 80, and R8 as well.
I think...
If it says to align PB for -5.5VU @ 250nWb/m reference, and would be -8.5VU @ 185 (for the reference tape I'm using),... would still point to 0VU being at +8.5dB/185, and so would be logical to follow thru with alignments for a +9/185 tape in normal use. (499. 996, SM900). Even though my techy stuff has stalled for the week, that's how I'll proceed. The only part left in the manual that seems dubious is the paragraph where 457 or 227 is recommended, when the other evidence points to +9/185. +8.5/185 would point to 514nWb/mm @ 0VU, is my closest estimation. Just proof again that Fostex was marching to the beat of it's own drummer, and the manual has some inconsistencies.
I have a few 5" reels of 996 to play around with.
What's your quick take on how 480 would perform against those alignments? I have more than several reels of 480 to mess with.
Thank you!
:spank::eek:;)
If I may chime in here, I think this is a salient point. Can the Model 20's transport even handle 1.5-2mm thick tape? The manual doesn't even recommend 456, so I'd think you'd be shortening the deck's life significantly more by attempting to consistently run SM900/GP9/ATR on it.
All very good points,...
thank you!
I only wish the manual and calibration sections didn't have these "little" inconsistencies. What gives when the say to align +8.5/185 (514nWb/m @ 0VU)? Then in another section recommend 457/227? It doesn't make sense to me. The Model 80 recommended G320 (+4/185) and then 457 tape, which made a lot more sense to me and appeared consistent.
OTOH, even though 1.5 mil tape is not recommended directly, I believe the Model 20's transport is plenty robust enough to handle it. The most direct contradicting point is there were really no +9 tapes available on 1 mil, at all, (although +9 on 7" reels/1200' seems to be available).
Yes that's a good point, as all the small format (7-inch reel) machines from Tascam, Fostex and others specify 1-mil tape like Ampex 457. For example, 457 is the recommended tape for the Fostex A2, A4, A8, Model 80, R8, and the Tascam 22-2 and 388 (Some manuals will say 357, but that was a home hi-fi version of 457 marketed to the general public). None of them suggest a 1.5 mil tape and some even caution against it. And +9 tapes tend to be thicker, heavier and more abrasive than any other type.
There may be a mistake in the wording of the Model 20, but considering when it was made and the manual was written (1985) it would make more sense to dismiss the idea of +9 tape because it had not been invented yet. The Model 20 precedes the invention of +9 tape by five years, which was 3M 996 in 1990, followed by Ampex 499 in 1991, then BASF SM900 in 1995, and Quantegy GP9 in 1998. The 90's was the decade of +9 tape. The Fostex Model 20 is a mid-80's machine.
Ampex 457 and 3M 227 were the right tapes as listed in the manual. From here you have to figure out what if anything is wrong with the calibration instructions.
The end result is,...
I used G320 (0VU @ +4/185nWb/m) reference and biased for 457. The manual specified bias 4dB over peak. All the other record/repro calibrations were done. I sold this unit to someone who was very happy to get such a clean and well working machine that had just been gone through. The "0VU @ 514nWb/m" in the manual still has me scratching my head. I'll leave the transaction knowing G320 is adequate and seems proper. Thank you!
:spank::eek:;)
This is a 10+ year old thread but pertinent to the topic at hand.
I'm using a Fostex E16 and I've got the G320 MRL tape. The short of it is that I'm not sure which flux level I'm actually running at when calibrating the machine as per the service manual. The reason I don't know is because the E16 has peak bargraph meters and not VU meters, and I hear there's a level difference between the two (VU shows 6dB hotter than PPM with a continuous signal I think?).
As mentioned in this thread the G320 standard is more a European way of calibrating things, but using PPM/peak meters. It's possible that this standard already has the level difference between VU and peak meters 'built in' to the calibration process. I don't know. In the end, if I want to calibrate for 456-type tape which is +6dB, I'm not sure that using the G320 MRL tape will get me to an actual 320 flux (288?) level when calibrating to 0dB using the peak meters. If so though, it'd put me at about a +4dB operating/flux level which isn't too far from the +6 blank tape standard. But I'm unsure.
Or just tell the interested buyer that you can set it for what he wants - the Fostex Way or the Good Way!
Peak-reading meters show program peaks. Averaging meters show an average level of the program dynamics. If you are measuring test tone there are no dynamics to average…it’s a constant non-complex source whether at the input or from a test tape, so both meter types are going to reflect the same level given the same source. Does that make sense? You’re over-complicating things.
The E-16 inputs are -10dBv nominal. Test tone at the input should measure 0 on the meters when calibrating the meters.
The E-16 is also intended to use “+9” class tape like 499, GP9, SM900, etc. So the electronics are intended to print a -10dBv nominal input signal to tape at 320nWb/m. If you want to use a “+6” class tape like 456 or SM911, and you want set the machine up for printing to tape at 250nWb/m using your 320nWb/m tape, simply adjust the playback level of the test tape to show +3 on your meters rather than 0. Your test tape fluxivity is hotter than what you want the setup to be. So adjust the playback level to reflect that. Then when you are setting the record level using your “+6” class tape, and monitoring the playback of the recorded -10dBv tone, assuming you calibrated the meters at the very beginning, adjusting the record level for playback at 0 on the meters will reflect 250nWb/m printed to tape.
I thought I read that PPM meters give a different average/RMS level than a VU meter does by 6dB or 8dB, so that's what was confusing me. I know the 'peaks' won't even come through on a VU, but the average level was what I thought I read about.
It was recommended to use 456 or +6 tape for the E16. If I just calibrate to 0 using my G320 tape as per the service manual, it'd put me in the ballpark of about +4 I believe, which is close enough to 456 +6 tape.
I don’t know what you read. You’d have to provide more specifics. It what I can tell you is PPM meters display the peak of the program material…PPM stands for Peak Program Meter. PPM meters can be digital (LED or plasma for instance) or analog. So what you see is more representative of the actual level of the program as it varies. An averaging type volume unit meter, like the majority I’ve encountered on tape machines, show an average of the program as the level varies…often there are peak indicators so you can see when signal is clipping because the averaging type VU meter is not going to show you your peak levels, again, because they are showing an average of the program over time. Averaging meters will display a lower level relative to the PPM meters given the same source program. Regardless of the differences between averaging type meters and PPM meters, the meters on your tape machine are PPM type. And the specs indicate when you are calibrating the meters, when monitoring a 0.316V 1kHz sinus tone of the input, the meter should read 0. And when monitoring the level set tone from a 320nWb/m standard tape, the playback level should be adjusted so the meters read 0.
I’ve been running this around in my brain and I think you are on the money…I was originally thinking Fostex intended the E-8/E-16 use +9 class tape because of the reference fluxivity of 320nWb/m. 320 is not quite the typical reference level of 355nWb/m I often see for +9 tape like 499, but it’s significantly more than the typical 250nWb/m for +6 tape. But high levels on such a narrow format machine usually spells crosstalk troubles…and now I’m finally in the same headspace as you are…I think…they chose PPM meters, which will read higher than averaging meters…and the 320nWb/m reference level compensates for this if the machine is calibrated per the service manual, so when using the 320nWb/m reference fluxivity and the PPM meters, it’s a very similar setup to a machine with averaging meters and a 260nWb/m reference fluxivity…I agree the machine is designed for +6 class tape like 456, and following the calibration instructions in the service manual sets the machine up for that class of tape. I think we are saying the same thing, just from a different vantage point.
Sorry if I confused things or lead you astray while I got my head straight. It’s an unusual setup, but the PPM meters are the reason. And there’s nothing wrong with them. The trick is knowing they display peak program information…good to go.
