S
sebo106
Hello,
This is my second post on this forum. In first one I found out what should I do to record a voice over in a decent quality. I already made some recordings with ZOOM H4, 96kHz, WAW. The recording consists of separate words, which will be cropped and stored as separate samples to use in a vocabulary teaching software.
I attach a sample of the recording which wasn’t processed anyhow or changed – apart from saving it to MP3 because of the large file size of WAWs.
here is the sample: View attachment sample Rec1.mp3
I am new to sound editing and I wouldn’t really want to know everything about it as I will only need it for this specific task – to make the words sound clear for the learner. I know that the most important to do is normalization and noice reduction but also the recording needs to be passed by some effects to sound properly.
I use Adobe Audition software
What I would ask you is advice for:
First of all which processes should I do since the beginning and what should be the sequence of them. What is most important - which filters should I use to make the higher tones up that it would sound more clearly, warmly and impressively than now. Generally – how to improve the recording. What would you suggest?
Secondly – the P’s explosion. As you can hear in the sample the word DROP has the explotion ( it happens when P is at the ends). I tried some advices from forum and used FFT filter Kill the Mic Rumble but that doesn’t entirely remove the unpleasant effect. I wonder if there is a way to get rid of them or I would need to rerecord those words (it’d be nice to avoid rerecording ;-),
I will be very very grateful for any of your advice, suggestion or opinion. I am new to audio editing, and just want to learn how to improve recording in this specific task.
Hope you can help me with this issue,
Thanks in advance. Sebastian
