D
davecg321
I am attempting to e.q the stereo out on track i am working on.
I am using cubase 5 studio eq and want to use a high pass filter to remove bottom end below 35Hz.
I seem to have a problem as when i set the high pass there (35hz) it slowly starts rolling off from around 100Hz down to 20db at 0Hz
This is obviously a problem as i am still getting some lower end coming through. Is it not ideal to have a steeper slope to completely remove anything below 35Hz???
do i need a different e.q plugin?
many thanks
many thanks
) Truth B2092A. On the home page it says it runs linear down to 32hz, but really you can hear-feel below it. I don't remember exactly the results, but I did a test few years ago with signal generator to see how low does the signal dissapear. I can do a test again if you like.
