When is it time for a fret job?
  • Thread starter Thread starter Tadpui
My solution....have more guitars! :D
That way you don't ever have to overplay any one. ;)[/QUOTE]
All I can say is thank you!!! You've given me the perfect reply when my wife asks why I need another guitar. May I say you are just brilliant Miroslav!
Posted at the same time, Miro. Great minds and all that.
I have no issues with what you've posted and I wasn't trying to get you and Mutt in each others' shit. It's all good man. The guitar ain't perfect and neither are we.
I got nothing to get into with Mutt. :)
OK...here's another "Miro-tuning" thing you can chuckle about. :D
So everything I said earlier still stands. When I finish setting up and tuning a guitar, I've added one more step.
I have a decent number of guitars...a few vintage ones that I don't beat up too often, a couple of "special purpose"....but also a bunch of my "every day" guitars. As I said earlier, I find that you can tune similar models identically, and they will still have their individual tuning personality (another reason why just one "standard" method doesn't always work, and everyone ends up fudging as they play to compensate).
Now...I happen to have one tuner that allows me to program into it eight of my own "sweetened" tunings (along with a lot of the commercial ones out there...Buzz Feiten, etc that are already in the tuner.)
What I've done with eight of my "every day" guitars, is once I set them up as perfectly as I could, make note of whatever "personality" each one has, the little bit of "offset" needed here-n-there...which is going to be different for each of the other guitars...and then I program those differences into my tuner, that way when I pick up a particular guitar, I punch up my sweetened tuning for it.
It just speeds up the tuning process and gets that specific guitar into its fine-tuned mode easier.
Now climate will always play a part, and force additional changes when it swings form one extreme to another...but the guitar's personality never changes permanently (maybe slowly over many years)....so I have these programmed tunings I can use, and I can always reprogram if needed.
This is just another little time-saver, and when I'm recording and rechecking my tuning after every 2-3 passes for the sake of continuity in accuracy, and later comping in the DAW...the programmed "personality" tunings make it easier.
Mutt only knows what mutt knows and anything else he scoffs at.
Nothing new there...that's old news, and he's not going to really debunk what I said, 'cuz he can't...he'll just scoff at it as he usually does.
The intonation method I mentioned earlier is not something I came up with...it's a legit method, and an alternative to the old harmonic/12th fret approach which can work in a lot of cases, but the alternative provides a sweeter tunning across the entire neck and minimizes the amount of needed as-you-play adjustments that Mutt was referring to earlier.
It does take longer to intonate with this alternative method, but I wouldn't be continuing to use it on the rest of my guitars if it was worse than the "standard" method or if it made no difference at all.
I can point you to a website that describes the alternative method....if you think it's just something I made up. :D
Try both...use what you prefer.
AFA the pressing of the sting to tune rather than doing the traditional open string tune....that's my own, though I'm sure someone else did it before me. That's just pure common sense, because when you press a string (as was already discussed somewhat within the jumbo vs smaller fret discussion)...it's going to stretch the string from its open string position, and change the tuning slightly...just like pressing too hard with jumbo frets.
If you play open a lot and mostly in the first 3 frets...tune with the open strings.
But if you're like me, and especially when playing electric, you are pressing on the strings 95% of the time....WTF would you want to tune to open strings for...? ;)
And the other point, about occasionally fine-tuning for a specific range of the neck...well, that's mostly a studio thing, where you're going to lay down one track and play a specific set of chords/licks. If they happen all to occur say, between the 5th and 12th frets...press/tune your strings in that area and you will fine-tune for that.
This too is nothing unusual or weird....it's been done before I ever did it.
For overall playing, live gig playing....you certainly wouldn't want to fine-tune for a specific range of the neck.
Like I said, it's just a studio thing, no different than say tuning so that the 3-4 chords you may be using for a given song are as prefect sounding as possible relative to each other and the song...and not worry about chords in other positions that may be off, which you are not going to play anyway.
Say you're doing mostly minor chords on a track, all within a few frets of each other, you can tune more specific to them, and they will sound sweeter. Again...that's nothing new or rocket science, and it works better for some things than other....but occasionally it helps a lot if you want to get the best tuned sound on a track.
At any rate, take the time to try it all and if doesn't work for you...you don't have to do it...
...or you can avoid trying it and just follow Mutt's absolute/only approach.
Oh Mutt....the last couple of threads where you said I needed to get the last word in, you went on for another handfull of posts well after me....so I'll take this one, ...that is, if you decide not to reply. :)
See what I mean.
See what I mean.
See what I mean.
Miro being Miro. Good thing he's not a mod, yeah? ;)
I don't think anyone here knows the science of the damned thing like you do but I am interested in how other people approach the inefficiencies (good word here?) of guitar tuning. If it "works" for Miro's ears that's a good thing for him and maybe an angle others might try. YMMV and all that... The absolute of the thing is not in question. The resolutions - however inadequate - are bound to differ. It's like Scott taking ponies and Amundson dogs. (Maybe best not to go there...bloody skandahoovians!)
Scott + Ponies (& tractors initially) = disaster for EVERYONE involved
Admunson + Dogs = 1st, surviving & not getting very much press in the Commonwealth.
I've noted that the adjustment my luthier made to my semi acoustics, ( to make it easier for me to keep the floating bridge in place he moved it away from the bridge & hard up against the bridge pickup rather than in line with the F hole notches & set the bridge intonation for best fit), means that no tuning process gets me good intonation beyond 5th fret, (luckily I don't play lead or barre chords).
Geeze, I must've come across as totally ignorant for him to decide to do that.
Have you tried the tuning method described in the temperament sticky? If he has set your intonation correctly it will give you the best way of splitting the tuning discrepancies across all intervals. Remember not one word of this is my opinion or one word of it originally mine. This problem was first identified by Pythagoras and every generation of composers and musicians as well as luthiers have dealt with and accepted compromises as a result. It is just the way it is.
Here is the tuning method that is advocated by GAL and it is the simplest method I have come across to achieve what we are after. There are other methods but they all essentially achieve the same thing.
Stagepass.com - How To Tune The Guitar to perfection
Just try a level & re-crown job, unless the wear is extreme. Probably about $100 at most shops. If you have access to a good shop, it could make a world of difference in playability. I have even had new guitars leveled & re-crowned.
Note: I'm referring to a level & re-crown of ALL frets, not just redressing.
You need a fret job when the frets have been filed as much as possible.
On my old '66 strat my guitar guy would always say. "we may be able to dress and level them again...let me give it a shot" and I did that 3 times over the course of many years.
The time finally came when he
said "can't take them down anymore without damaging your fretboard man. We're going to have to refret"
It scared the hell out of me because the guitar played SO good and I didn't know how a refret was going to affect it.
It came out great but I went with a guy that is the best in the state ( or at least that is his reputation amoung players)
Go with someone who is really good at refrets...even if you have to pay more.
^^^ This ^^^
It only needs doing when the old frets no longer function and cannot be dressed to correct them.
Boy Mutt...youo haven't debunked anything I've said here....you just keep quoting me over and over and over.....
Looking at how often you quote me in threads even when I'm not directly responding to you or quoting you...
...someone might think you having some OCD going on.
I mean...it's almost flattering that you focus so much on everyting I say (even if it is a bit weird)....but you go right ahead, if this fixation of yours provides a little mental release for you....
:thumbs up:
:thumbs up:
It doesn't work like that but I don't have the energy to get involved with one of miroslav's "must have the last word" threads.
Intervals are intervals where ever you play them on the neck. If one is close others are not. There is no magical solution as the maths, physics and science can demonstrate.
You've read the sticky about the best way to tune to minimise the affect of compound intonation errors? Thats the best way forward.
See what I mean..
