T
twangbuck
Ok, so I have an HP i5-2400 quad core pc on order and coming soon (3.1 GHz - up to 3.4 - w/4 GB of RAM installed and a 500 GB hard drive, Windows 7 64 bit). I have Cubase LE which I'm going to install once it arrives, and I have a Seagate 1TB external hard drive that I'm going to set up too.
My question is about interfaces. I'm a little confused about interfaces and analog to digital converters. I already have an older TC Electronic M-300 processor, which has a 24 bit analog to digital converter w/a sample rate of 44.1 KHz and quarter inch outputs or an SPDIF output.
Am I better off going with a USB interface? Something like the Focusrite Scarlett? If I'm better off going w/a USB interface, I really don't want to spend more than about $100, and I'm seeing Scarlett's online for that amount. I've heard good things about it and I know it's got a 96 KHz sample rate and 24 bit conversion. So am I correct in assuming that because it's a higher sample rate than my M300 that it's going to be a nice upgrade in terms of sound quality?
What about the analog to digital converter? Am I correct in assuming that the Scarlett is going to serve that function? After all, isn't that kind of the point of owning it? Or is that something that I'll need something else to handle? If so, then why buy the Scarlett?
Thanks for the help!
