S
simon96
What is mixing?
Let's say I finally recorded all the tracks I needed, what should I do then?
Ok, so once I finished levelling, adding effects and panning my tracks I should bounce down all of them? I think I should make a copy of the whole project before doing it, am i right?
Anyway, after bouncing them what should I do? (I know I should probably ask this question in the Mastering section, but if you are willing to answer me here I will really appreciate it!)
) until you learn the art then. My best advice look up mastering studio's in your area and go check them out and try to learn from the professionals there in your local area, also we have plenty of people that are willing to help you right here. For me its just to much typing I think I would need to purchase Dragon Nuance before I try to start explaining to a young eng the art of mastering and it still wont work out lol.
@jaynm26
Thank you for your very clear answer, now I'm not full of doubts as I was before! ;D
@kip4
I don't want to get into mastering, I just wanted to know what's the difference between it and mixing!![]()
Can I make a suggestion....
Instead of asking short, individual start-up questions about this step and that step...why not type "audio mixing" and/or "audio mastering" in Google or your favorite search engine (or search here at HR), and then check out the results you get, there will be many.
Asking the most basic questions here only makes people re-type what has already been typed a thousand times all over the Internet, and there are some complete and concise tutorials already out there.
When you get stuck on some specific point AFTER you've learned some basics or at least tried some recording with what you know....it will be much more fruitful then to ask questions here.![]()
Mixing is when you take all the tracks you've recorded and want to use and mix them all together in such a way that you have now sounds like a song and not just a bunch of tracks that you've recorded. That means some tracks will be louder than others, different tracks will be put in different parts of the sound spectrum.What is mixing?
I'd record something first before you worry about mixing !I'd learn to mix first before you worry about mastering.
I still haven't recorded nothing
