T
teeboy
My interface has a button that is named mono but when i turn it on i still hear on both of my monitors and that to me is still stereo,i stand to be corrected. Pls explanations
I've seen Massive state this now for a few years and no one has ever contradicted it or disagreed with it so that's my definition of stereo until further notice !"Stereo" is the difference between left and right.
But won't these alter once you set things in stereo ?you can check mixes in Mono, this puts everything in the same position and allows setting eq and volumes.
I'm still waiting for someone to explain how a stereo mix gets to sound right in mono.some say "if it sounds good in mono it will sound great in stereo"....
But won't masking be more of an issue in mono ? Wouldn't it be the case that alot of those kind of issues disappear once you're putting sounds in different non competing places in the 'stereo field' ?it can help force masking issues out /crowding freqs,
I use it sometimes to see if anything is waaay out there, too loud or too much going on in one frequency area.
Is it possible to 'pan in mono' ? Someone mentioned it in one of these mono discussions a while back.sometimes I'll record in mono, numerous tracks = all panned in the center.
I think I know what the OP means because my interface has a mono/stereo switch that does nothing.. I just use a mono button on a stereo imaging plug inserted on my master buss instead.
what do you use the mono button for specifically?
I don't even touch the pan controls until the mix sounds decent in mono. I'd dare to say that it's almost "universally" true that if a mix sounds "right" in mono, it's going to sound "right" in stereo - But it's not at all necessarily true the other way around. And on the flip side, the best sounding mixes almost "universally" sound good in mono also.I personally have never yet made a mix decision monitoring in mono which made the stereo mix worse. I think the only way to convince the skeptics is to make them try it. We'll see how that turns out...
Sometimes, the 'skeptics' as you refer to them are not being skeptical. They're posing questions because they are seeking to learn and get their head around a concept that they happen to find difficult.I personally have never yet made a mix decision monitoring in mono which made the stereo mix worse. I think the only way to convince the skeptics is to make them try it. We'll see how that turns out...
I'm still trying to figure out this whole mono thing so hopefully, you can help me here.I don't even touch the pan controls until the mix sounds decent in mono.
I sometimes do track in stereo but most of the time I do so in mono. But then, it depends on whether I'm overdubbing. Initial tracking with drums or percussion and bass or guitar is generally done in mono. It feels unbalanced otherwise.in another way to ask that, do you not pan and have the bands headphones in stereo during tracking?
If you can get all the elements in a mix to "play well" with each other while coming from a single point, they will still sit just as well if you start moving them around in the field.I'm still trying to figure out this whole mono thing so hopefully, you can help me here.
Say you've got the mix sounding decent in mono, are all your settings going to remain the same once you start panning stuff or do you alter anything ?
I find it quite interesting that in the 'old days' albums came in both mono and stereo format. The engineers had specific mixing sessions for both. Obviously a mono mix will work in stereo because there's no difference in the information {if I take your definition}. How can a stereo mix work in mono ? Thus far, whenever I've asked the question, the replies I get concern things like masking and balances and settings. But where I have a problem understanding is this; if stereo is the difference between left and right and mono has no difference, then how can stereo mixes work in mono ?
