D
Devon8822
Hey, I've been having some pretty bad issues tracking DI bass lately and have exhausted so much time into troubleshooting it, I have finally narrowed down somewhat where the issue lies but i'm pretty stumped about what to do next. Basically, when recording DI bass I am getting the sound of clipping with aggressive/slap playing, without any visible clipping, even with pads and attenuation everywhere. I have swapped out mic pres (API 3124+, Daking mic pre IV, Apogee Duet)... the problem remains. I have tried different converters (Lynx Aurora 16, Apogee Duet), the problem remains. I swapped pickups and eventually borrowed some other bass guitars to test... the problem remained. The one thing I have not swapped out is the computer/DAW.
What was very revealing today was that my problem did something different than usual. I plugged in my bass and started playing through the DI out my monitors and it sounds great, the low end was back and the clipping was gone. So I clicked "record" and immediately my problem returned... so than I switch from my usual sample rate of 96kHz to 88 Khz and than back to 96, just to reset the interface/connection, and w/e else that resets in the DAW i dont know... and it worked again. I tried this test multiple times with different basses and gear once again and it was consistent. Every time I clicked record the problem returned. Note that after clicking record I could turn off the recording and just play live through my monitors and the problem would still be there until I reset the sample rate. Also, when monitoring the signal was going through the same conversion and everything as when recording, I was not direct monitoring/analog.
I would really appreciate if anybody had some insight on this? thanks!
