SteveM
Does anyone know if there is just one relay for all the buttons? Or would it have to be something else? All the buttons stop working all at once, intermittently.
How's it going Jeff? That's a surprise. I'll have to go in there and find out I guess. Thanks for the suggestion. I can't imagine what else would control all the buttons.
It's going OK, I guess.
I just took a peek at the schematics for a 3440 transport, which should be very similar to yours and didn't see any relays in that part of the circuitry that controls the transport, so any clicks or clunk sounds you're use to hearing in there might just be the brakes or the solenoid to move the pinch roller in or out. So yeah, most likely, just a grimy connector, maybe even pin 7 of that harness, which is the ground connection for all the transport buttons on that separate transport button board or the wire harness that connects it to the transport control board.
Good luck!
Cheers!![]()
Alternatively, if you have the remote control, RC120?, then maybe you could just use that instead.
Cheers!![]()
