witzendoz
Senior Member
First up I checked the 202 specs and it's actual max is +2 (-10 with headroom), so a loud +4 output may be a bit hot, I understand the problem that there is no way to turn down the incoming volume unless the device plugged in has a output volume control. A cassette deck would usually only be a -10 output so even a maxed tape will not overload the 202, I have converted tons of tapes to digital and never had an overload problem.
The mono thing is, if you create a mono track in say Sound forge, it sums the L & R inputs to mono, I have done this when recording lectures from a PA system, in this case as the cassette is alreay mono there should be no phase issues. I assume most softwere will do this.
Cheers
Alan
Cheers
Alan
