ranjam
........ don't go snipping bits and pieces in your new amp if you're not 100% comfy with doing so..
As Charlie Chan would say.... Egg-Zachary. To repeat myself; the 'brite' circuit is that cap you could snip, if you felt up to the task. But again, '10' is '10', and no effect would be heard. At say '7' on the volume control, some may call it 'duller', some may call it 'warmer', but it wouldn't be as 'trebly'. At lower volumes, the highs go through the capacitor and not the volume control. You do this all the time on your guitar. But '10' effectively shorts out the treble peaking circuit, so the full range goes on to the next tube.
If you always play the amp on '10', then this is a moot exercise. But I'll back pedal and say take it to a tech. It can't be more than an hour of his time; 1/2 hour to snip out the brite cap. An hour to pull the chassis and bump up C1.
