G
		Graymalkin2001
I'm a multi-instrumentalist, but as a vocalist, I need help.  Thus, the equipment in my chain.  As currently used, I come very close to sounding like a singer; actually fits my songwriting style fairly well.
I use a Rode NT1000 into an ART TPS-II hybrid tube preamp, to an Alesis DEQ230 equalizer, to a BBE MaxCom compressor with SonicMaximizer, then on to the Tascam 2488 NEO. It works well for me.
Here's the problem: I wanted to do something to discreetly correct pitch, so I broke out my TC Helicon VoiceLive. I only intend to use the VoiceLive for a touch of pitch correction, and perhaps thickening on a song or two.
I'm thinking about using the pitch correction directly after the mic, and before the preamp. Since the Rode has an output impedance of 100 Hz, I typically adjust the input impedance of the preamp to about 1000 Hz, to good effect. The problem is, the VoiceLive output impedance in 40 Hz. So, to use it directly before the preamp, should I have the preamp's impedance set to around 400 Hz?
And, is it best to use the pitch correction before the preamp, or would it be best elsewhere in the chain?
Much obliged for any and all suggestions!
