interesting ...... so IF a signal went on for 5 minutes at 0db but NEVER went above it the clip light would still be screaming CLIPPING.
Yes, but the only way that could happen is if you were running DC current into it at full scale. Remember, each cycle of a wave will only be so many samples long. The lower the frequency, the more samples will be used to capture it. The higher the frequency, the less samples.
In a perfect world, something that peaks at 0dbfs would only have one sample that is a 0dbfs which will represent the very tippy-top of the waveform. That will not trigger the clip light. But if you turn the volume of the wave up a little more, the peak will be squared off and the converter will spit out consecutive 0dbfs samples until the waveform drops back below that level.
If they make the clip light really sensitive, you could just be clipping a few samples and you won't notice something like that. (mainly because it's clipping for such a short time, you can't hear it. Imagine how short a period of time 1/44100 of a second is. Even if you multiply it by 10, it still goes by really quick)
As for the 32 bit thing ....... I use a Fostex D1624 for my recording. I'm assuming that 32bit thing doesn't apply to a hardware digital recorder.
But I still get occassions where I see clip lights but hear no problem.
So is that the sampling thing or do hardware recorders also process at a higher bit size while ITB?
You would have to look that up for your machine. I know the Roland 2480 was just 24 bit fixed point and it was really easy to clip at any stage of the mixer. Unfortunately, with that sort of a setup, you can be clipping the crap out of the mix buss, and if you turn the master fader down it will turn off the clip light but you are still clipping the mix buss.
Like anything in audio, if you don't hear a problem, it's not a problem. There is really no reason to be mixing or recording that hot, but if it isn't causing audible problems...
