elbandito
potential lunch winner
Ever heard of this program?
Curioza's Auto Audio Mastering System
Seems like it could be a great learning tool but to let an algorithm master my music on it's own? I'm not so sure. The demo has a 21-day trial period, so I may give it a whirl and compare some stuff that I have had professionally mastered against it's internal DSP processing and see how it sounds.
Does this seem as crazy to all of you as it does to me?
When ever you need a fast way to cover your mix into a full master ?
AAMS will do the job without fiddling with Equalizer, Compression, Loudness or Mastering functions settings yourself. AAMS automaticly generates suggestions from the differences between the Source audio material and the Reference choosen out of the 100+ Reference Style Database (or your own reference). AAMS will automatically produce a finished master by using its internal DSP-Processing. All you do is get your audio material analyzed with AAMS, Load a Source, choose a Reference Style to match and let AAMS internal processing analyze your mix and calculate all suggestions for a great sounding master. AAMS internal DSP processing can directly let you hear and process the Source audio material.
