T
Tonalta
My home studio is set up in a room that is 12' x 10' (See attached diagram). The walls are made of sheetrock. (Standard bedroom construction materials). I have my desk and monitor speakers positioned in the middle of one of the 12' walls that is uninterrupted. Near the center of the wall to my left is a 3 1/2' x 2' bookshelf and in the wall to my right is 2 standard size windows, side-by-side (approx 4'x5' total glazed area). The 12' wall behind me is comprised mostly of a large closet enclosed by two sliding doors. The room's floor is hardwood, a third of which is covered by a oriental rug. I have a fabric-covered easy chair in the right-hand corner behind me (which I assume is soaking up some frequencies). The door to the room is in the corner behind me and to the left.
The treatment I plan is mostly standard - one 24"24"x1" acoustic panel at ear level on the wall to my left, one 24"24"x1" acoustic panel covering one of the windows to my right and two 24"24"x1" acoustic panels on the wall in front of me directly behind my computer. I may put one foam bass trap in each of the corners at about the 3' mark when I can afford them. For now, the immediate treatment will be the panels. The panel vendor will very likely be Acoustimac.
My question is regarding what to do with the closet behind me. Should I take off the closet doors and move the aforementioned bookshelf into the closet to act as a diffuser? I have another bookshelf about the same dimensions that I could place right next to it. Both shelves are full of books of various sizes. Maybe I could hang a heavy curtain in place of the sliding doors? Also, would it be better to cover the window to my right with venetian blinds instead of an acoustic panel as a compromise to window visibility? I believe I read recently that blinds can act as a diffuser.
Thanks for your input...
What DO foam "bass traps" do?
