R
ritb
Friends,
This is a radio program. Pls. suggest me what can I do to make it better.
This recording is with a headset attached with my onboard soundcard mic-in.Can you explain your recording setup in detail? I have a feeling the problem lies in your mic.
I have added some reverb. But still its not very good.Sounds like USB headset mics to me. A little reverb couldn't hurt.
Why my vocals are dull and lifeless?
Radio station is creating problems. They are not aware of what we use. Main problem is we have already recorded 14 programs. So pls. suggest me How can I make it better/brighter/punchy?For starters, don't do this!!! Find out what other broadcasters are using and do something similar.
Is this really a radio broadcast or a podcast?? Can't believe a radio station would let anyone use a computer headset.....
This is actually pretty bad, sorry.
Simplest solution:
- usb interface (m-audio fast track mk2 for example)
- mic (shure sm58 for example). Many radio stations use shure sm7 or EV re20 so you can check these out, but they are pretty expensive.
- xlr cable, stand(, pop filter?)
= 10x better quality![]()
BTW, there's a children's audio book on my website that was done with an SM7b and an mbox 2.
It'd give you a good idea of what to expect from a modest upgrade. I don't imaging using an sm58 would have been all that different, really.
Ritb, It's true. You may be able to make some improvements, but there's no substitute for upgrading.
The main problem I hear is that the speech sounds very thin. You could try eqing to boost the lows or lower mids a little.
Try some gentle compression; You'll hear a lot of that on radio voices.
I'm not sure about reverb. Maybe you could play with a very tight warm room setting? I certainly wouldn't use anything that's obviously reverb, if that makes sense.
thanks friends. I shall try to do like wise.
that kids audio book is nicely recorded.
How can I add the chorus effect? is it part of reverb effect?
