M
Myrtonos
Given all the debate about (linear) analog versus digital recording, I thought I'd mention FM recording.
Let's first note that analog audio recording requires a bias, becasue of a magnetic propety called hysteresis. It seems that this bias is higher than the maximum frequency allowed by the head gap.
Also, when you playback a magnetic recording, the playback output increases with frequecy by 6db per octave. Normally in audio recording, an equaliser is used on playback to hold down the higher frequencies. This method (so it seems) works as long as the signal is (entirely) AC and the gain imbalance is no greater than the dynamic range of the medium.
Video signals (especially the luminance part) are fluctuating DC rather than AC, and thus span infinitely many octaves so the only way to record them is to modulate them onto a carrier and record the carrier. Frequency modulation is used becasue it permits recording a signal at constant amplitude, keeping the tape at saturation level, with no bias being necessary, and meaning that a simple limiter is sufficient for correcting gain imbalance and other amplitude variations. There also existed FM tape recorders for recording biological signals.
Yet FM was almost never used to record sound, the only example I know of is the HiFi modes on VHS and Beta videotapes. An audio format using wideband frequency modulation to record sound would have dynamic range and frequency response quite impressive for analog media.
I do wonder whether FM was seen as the future of audio recording as far back as 1956, when ampex introduced quadruplex, which, like all subsequent analog VTR formats used FM to record the luminance portion of the video signal.
