W
Wolfchild
Hi everybody!
It's my first post here and I would like to know your opinion on how I can get the most of home recorded vocals on the minimum possible budget
The ideia: I will be recording vocals over digital music that I will be writing on midi in guitar pro and then sample/ add effects/ mix on acoustica mixcraft. This is an hobbie and supposed to be as low cost as possible, but of course I want to get it to sound as good as I can (considering the limitations).
I basically have a laptop PC (Windows 7 64bit) and a Shure SM58 mike.
I've been browsing for the best low cost way to plug my SM58 to my PC and came across 3 possibilities: Buy an XLR/ USB adapter cable, buy an XLR/ 3.5mm jack adapter, or buy a pre-amp with a USB digital out (or even a pre-amp, line out and 3.5mm jack adapter, but somehow the previous version seems a better choice).
I've read that the USB connection used on an analog source will create noise due to the voltage on USB ports (not sure and also, my mike does not use phantom power); I also fear that using an unbalanced 3.5mm in for a balanced mike is like wiring a high quality stereo with low end cables.
The pre-amp choice seems the most obvious to me, but I'd like to be sure it's worth it (even though the pre-amp I'm considering is the "budget" Tube MP Project Series with USB, which is about 80€ or 100USD). Do you think it will make the difference to be worth getting it? Also, I haven't sung live in a few years now, but back in the day, most gigs my former band played used to have weak PAs so I ended up with low amplification on vocals (and being a baritone did not help to get my vocals stand out over the guitars as well), so would this pre-amp also be a good choice to use instead of these cheap PAs inbuilt pre-amps, in case I will sing live again in the future? I mean, would the input sound on the amplifier make the difference so that I would not need to sing so high and tire my voice?
Also the low frequence filter and the limiter seem to me as something that could be useful to improve the sound. I'll be recording at home, I don't have any special room, so I'll also need help in a few tricks to improve a bit the acoustics, but I'll leave that to later so I won't clutter this post too much.
