P
p_bruno87
At which ratio does a compressor commonly begin to become a limiter?
Little thumby up' thingy here...The "textbook" answer is 10:1.
The "people who don't like to smash everything" answer is probably closer to 3 or 4:1 (but is subjective).
When you think about it, 2:1 is cutting the dynamic range in half above your threshold. In half. That sounds pretty "limiting" to a lot of people also...
Wouldn't a lot of "limiting" have to do with the threshold?
I understand compression/limiting pretty well, I just don't use it super well sometimes.
My understanding of limiting is that when the signal hits the limiter threshold that's it. The signal does not get any louder once the limiter is acting. Therefore a true limiter is a (Infinite ratio) ∞:1. With an extremely fast attack.
Alan.
I don't see that. If 20:1 means that you need to go 20db over the threshold to get 1db over. So, if we assume that (infinity):1 is the same as 100:1, then you'd need to go 100db over the threshold to get 1db over. So, I'm pretty sure that infinity (i don't know how to make the "infinity" symbol) to 1 ratio, or even 50:1 ration is a pretty hard ceiling. I can't see anything going over the threshold with those ratios.Technically, the limit would be 1db over the threshold though, wouldn't it?
I'm not saying that to be picky. I'm saying it because I never actually processed that before.
Is it right?
I mean, you'd never do it I guess, but If you wanted to set a limiter for 0db, you'd actually set the threshold at -1 then, yeah?
Is it right?
So with inifity :1 (don't know the symbol either), the compressed level will technically pass the threshold, but not by a significant amount.
