somegeezer
4 Gazillion Rhodium User
sortof.
What I mean is using two or more interfaces relies on them being the same type and/or from the same manufacturer.
As I say, I might be a bit out of the loop. Maybe windows just does aggregate devices now, but if not then you can't add a firepod to your setup, for example, or even a delta 1010 (keeping it pci).
I doubt the OP can use both of his interfaces as interfaces, but he certainly should be able to use the line6 as a standalone preamp feeding the tascam over spdif,
This is why I went with a firewire Firestudio Project. As it gives me expandability if I need it.
USB interfaces seem to have a lot of trouble, mainly in Windows, when trying to use more than one. Whether from the same family or not, or so it seems. Everytime I've sen people with more than one interface for many channels, it's always been firewire setups.
Then again, most people seem to only really be able to get about 16 or so tracks when using USB, and there are interfaces with USB that have that many inputs if you need them. Whereas I know Presonus, at least, with their firewire interfaces, can all be daisy chained into a max of 52 inputs.
But I think my reasoning is otherwise sound.
