G
		So did I?
Honestly going from their description, coil tapping is fucking dumb.
When you drop from two coils to one in a humbucker, of course you lose the noise rejection, and you drop the total number of turns, which means lower inductance and output impedance. That changes not only the overall output of the system, but the frequency response as well, basically reducing high frequency losses and shifting any resonance to a higher frequency.
Rolling off volume "a little" actually does the opposite, it increases output impedance which means greater high frequency losses to cable capacitance, and reduces resonance because the output impedance becomes more resistive than inductive.
A very clever pickup would "tap" to a pair of underwound coils such that humbucking was maintained . . . basically each coil would need a 50% tap. I'd invent that, but I suspect somebody else already has . . .
What about switching from series to parallel in a humbucker?
Speaking of coil cutting/splitting.....I got this StewMac newsletter tip awhile ago that shows a few cool ways to rewire.
The one that interests me is where you can use one of your Tone pots to act as a variable blender of your split and non-split humbuckers for a variety of combination single/dual coil tones.
Trade Secrets! Newsletter at Stewart-MacDonald
